Home > General > 2 different brand turbos |
I’m not sure how the twin turbo set up in the V6 works, i.e. one turbo per bank or if like other cars (non V) has 2 turbos to give a better performance range. I wouldn’t see an issue or at least no more than having 1 new turbo and 1 well used one. As long as the spec is the same the performance should be the same. 2019 5.0 SC SVA (Current)
Fri Aug 03 2018 5:31pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Can’t answer your main question as to wether or not you can fit different brands of turbo, but the design is sequential turbos, with the second, smaller turbo, kicking in at higher revs, 2500 I believe. If you drive off fairly briskly and watch the revs you will see a significant boost as the second turbo comes in. |
Fri Aug 03 2018 6:49pm |
