Home > Technical > B service due on 12 year old sport
Andyjay123
Take it to a Land Rover specialist or my local garage who isn't a specialist.
Land Rover specialist want £450 for a B service where as the non specialist wants £272
Many thanks
Andy 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562304 Mon Jul 30 2018 5:02pm
Disco_Mikey
Spark plugs due at 6 years, I believe
Make sure the 2 quotes are like for like Thumbs Up
Post #562311 Mon Jul 30 2018 6:54pm
Andyjay123
Thanks Mikey
I assume if going to a L/R specialist they will more or less be spot on.
The £270 includes :
Check operation of external lights
Check operation of instrument warning lamps
Check horn
Internal - Vision Internal / Vision
Check door/bonnet/lock operation
Check windscreen wipers and washers operation and condition
Top up windscreen washer reservoir with additive if required
Check & advise on pollen filter condition
Check air conditioning system operation
Check windscreen for cracks and chips
Check mirror condition internal and external
Check number plate condition
Check seat belts
engine Engine
Drain engine oil
Replace oil filter
Refill with fresh oil
Replace air filter
Replace fuel filter if fitted externally from tank
Check and advise on general oil leaks
Check coolant level and top up
Advise on antifreeze strength
Check radiator and coolant hoses for condition and leaks including header tank
Check radiator cap
Check electrical coolant fan (if applicable)
Check condition and tension of auxiliary drive belts (NOT timing belt)
Change spark plugs on petrol engines dependent upon mileage - Extra Cost
Visual check fuel system + tank if visible
Check timing belt replacement intervals and advise
Check AdBlue (top up extra cost)
Brakes Brakes
Check/advise brake fluid condition and report
Top up brake fluid if required
Visual check of brake pads for wear
Visual check of brake disks for wear
Visual check all visible brake pipes and hoses
Check operation of hand brake
Visual check brake callipers for leaks and security
Tyres - Wheels Wheels and Tyres
Check tyre condition and tyre depths
Check and adjust tyre pressures
Remove and refit all road wheels.
Steering Suspension Steering and Suspension
Check condition of road springs
Check power steering fluid reservoir for leaks and top up
Check steering/suspension components
Check steering rack gaiters condition
Check shock absorber condition
Check wheel bearings
Exhaust Exhaust
Visually check exhaust smoke (diesel)
Visually check and advise on condition of exhaust
Drive Drive System
Check drive shaft gaiters for security and report leaks
Check clutch operation
Check clutch fluid level (if applicable)
Check transmission oil leaks
Final Checks Final Checks
Reset vehicle service light where applicable
Stamp service book
Stamp printout of BookMyGarage service schedule 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562314 Mon Jul 30 2018 6:58pm
Cymruambyth
Wales
I paid £278 which included front pads and inspection 2 service at a local garage (ex LR mechanic). Same job as specialist no doubt. Don`t waste your money Thumbs Up Steve.
Post #562319 Mon Jul 30 2018 7:24pm
Disco_Mikey
Whistle
Post #562323 Mon Jul 30 2018 7:55pm
Andyjay123
Ha ha
Are you suggesting they will tip me off!
The Land Rover specialist has come back and said best price £370 all in 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562324 Mon Jul 30 2018 7:57pm
Disco_Mikey
I expect with a set of spark plugs, they will be on par with the specialist Wink
Post #562326 Mon Jul 30 2018 8:33pm
Andyjay123
£104 for the spark plugs - 8 needed! jobs a good un 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562612 Fri Aug 03 2018 8:05pm
geoffsnook
Back ones are a bitch to change to Rolling with laughter
Post #562635 Sat Aug 04 2018 11:45am
Andyjay123
Spark plugs were changed at 6 years. Now it’s 12 years old I’m guessing I need a mother new set? What’s the worst that will happen if I don’t change them for another year 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562637 Sat Aug 04 2018 1:07pm
No big deal. If it's running smoothly leave it.
Post #562655 Sat Aug 04 2018 7:21pm
Andyjay123
Thanks Andy 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562656 Sat Aug 04 2018 7:25pm
