Home > Technical > Brake Pad Worn - Can I re-use the old sensor? |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
If it isn't worn and doesn't break when you take it out (they usually do), no reason why not.
Fri Jul 27 2018 11:33am |
^ As wilf says,,best thing is to spray with wd40 & leave to soak for half hour that sometimes work.
Fri Jul 27 2018 1:58pm |
i_dinler Member Since: 14 Nov 2015 Location: London Posts: 21 |
Yeap it broke so new sensor has been fitted.
Fri Jul 27 2018 8:12pm |
Gav40 Member Since: 12 Jul 2012 Location: Kent Posts: 30 |
Hi, can I ask what make of brake pad you fitted please as thinking of changing mine soon as squeal like a pig. |
Sat Jul 28 2018 5:16am |
I went for Brembo Pads. |
Sat Jul 28 2018 7:23am |
I won’t use mintex anymore as they aren’t mintex but Chinese boxed up as mintex,,a Chinese company bought mintex for the name.
Sat Jul 28 2018 7:26am |
Good to know but I have already fitted the rears, Initial thought they look no different than any other pads, wear wise time will tell.
Sat Jul 28 2018 10:35am |
This is a good place for discs & pads,,when mines due I’ll be fitting grooved discs & low dust pads.
Sat Jul 28 2018 10:43am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Why not use Advance Factors they are site sponsors, give discount and offer an excellent service. |
Sat Jul 28 2018 11:04am |
I would use them if they did the EBC low dust pads,,the original LR ones I have on at the minute are terrible for dust,I’ve only to drive a few miles after I’ve washed/cleaned the wheels & they are covered in dust again.
Sat Jul 28 2018 11:54am |
rodspink Member Since: 23 Jul 2017 Location: Angus Posts: 29 |
I keep spare sensors just incase I need to do anything on the brakes. they get really brittle. |
Mon Aug 06 2018 10:28pm |
