![]() | Home > Technical > Emergency Park Brake Release? |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
Yes exactly! How to do this on rotary selector models!
spooky Member Since: 15 Feb 2014 Location: Swiss Posts: 34 ![]() ![]() |
Here it is... Indeed a bit different, I just needed to know it's possible |
Is there a removable cap in there? Visitor from fullfatrr.com
Hi Dr Rob
Yes, you see the disk? it can be removed easily with a screwdriver, then you have access to the cable. Then the procedure is the same as with the old RRS, using the jack part which is in the trunk.
I'll assume the 8 speed rotary is the same but might check to be sure |
On rotary gear selector models access to the parking brake release is straight forward.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
just checked, no tool nor screwdriver in my tool kit |
This thread seems to contradict http://www.rrsport.co.uk/forum/topic34685.html Quoted from the thread: The rotary knob type (later sport) has a red lever under the cup holder (easy to lift out the way). This is the release from the gearbox being in park (maybe after a flat battery) and you can't use the gear selector. No force need to use this one. The EPB emergency release is still the old wire loop. This is located under the EPB switch in the centre console. Lift off the flappy bit of plastic in the well of the switch with your finger to expose a pair of screws holding the switch in place. You need a T10 torx to undo these and don't drop them unless you want to dis mental the entire centre console to retrive! Now lift the switch up (still attached to a cable plug) and in the very narrow gap, you can just about make out the wire loop. Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Monffo Member Since: 10 Jun 2014 Location: France Posts: 2 ![]() ![]() |
Hi there. Just had this problem with my 2010 RRS. I have found the small round plastic cover under the cupholders and have opened it but can't then see what to do. Could you help with a bit more of a detailed explanation please? Many thanks, Simon |
