Home > Wheels & Tyres > Another ballache.
Cymruambyth
Wales
That was one of the links they gave me. Should be ok then Thumbs Up Steve.
Post #561943 Tue Jul 24 2018 2:49pm
DrRob
Replace all 20 nuts with solid, non capped ones.
I put a link up to the ones I fitted a while back.
Fit and forget.... Visitor from fullfatrr.com
Post #561946 Tue Jul 24 2018 4:41pm
Cymruambyth
Wales
Good idea...but I`ll be spending as little as possible cos it`ll be going soon Thumbs Up Steve.
Post #561947 Tue Jul 24 2018 4:44pm
Stevepd
Steve just checked and £14 for four nuts.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #561957 Tue Jul 24 2018 7:12pm
Cymruambyth
Wales
Cheers mate. Just ordered 4. They were £18 with delivery Thumbs Up Steve.
Post #561958 Tue Jul 24 2018 7:13pm
Yay, that's the attitude. We can talk the next owner through their problems too. Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #561966 Tue Jul 24 2018 9:52pm
Cymruambyth
Wales
Why the Censored would I spend over £50 on a set of nuts when realistically I only need 4 FFS? Steve.
Post #561967 Tue Jul 24 2018 9:55pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
My indy diagnosed the swollen nuts issue when it was in the other week, only on one wheel. His advice is that its best changing out the lot as the price difference is not significant but where you have some failing others might follow and the originals are renowned for it. So not absolutely required but preventative maintenance, or just trust to luck and just buy for one wheel.
Post #561974 Wed Jul 25 2018 6:39am
Cymruambyth
Wales
I`m just replacing the Censored locking ones at the moment so I can get the second tyre fitted. I`ve just spent over £300 on 2 tyres which someone else will get the benefit from as i`ll be getting shot soon. If the new owner wants new nuts.....crack on Thumbs Up Steve.
Post #562035 Wed Jul 25 2018 8:32pm
DEVON
Just my two pennies worth Steve if you wanted to try it yourself.
I had the same issue with the Censored locking nuts , and I like to try everything myself before paying someone else to do it . So I thought what’s the worst that can happen ? I used a long thin chisel and screwdriver to punch a hole through the center of the the spinning nut , you will find it is only thin metal . Using the screwdriver to “peel” the metal open , I then used the chisel to “break” the metal off . Underneath I was surprised to find a hollow nut which you can then loosen off with a normal socket , from memory I think it was 19mm .
I caused no damage to the wheel , and the whole process took me 20 minutes tops .
Hope this helps Thumbs Up
Post #562041 Wed Jul 25 2018 9:31pm
Cymruambyth
Wales
Thanks for that matey. Unfortunately it`s already at the garage Big Cry Shouldn`t cost too much....I hope Thumbs Up Steve.
Post #562083 Thu Jul 26 2018 8:39pm
DEVON
Rolling with laughter Rolling with laughter
No problem my friend Thumbs Up
Post #562089 Thu Jul 26 2018 11:43pm
Cymruambyth
Wales
I`ll have to ask him how he gets them off.....might be the same way as yours Laughing Steve.
Post #562112 Fri Jul 27 2018 9:41am
