![]() | Home > Faults & Fixes > Split boot help needed RRS (58) |
The switch corrodes. It's a DIY replacement job for a few quid. Do a search on the forum as it's a common enough issue.
waynescott523 Member Since: 09 Jun 2018 Location: Southport Posts: 61 ![]() ![]() ![]() |
Thanks for your reply I shall give that a try later, it's strange it's just suddenly just stopped working in the last day or two, but then again these are range rover for you !! Much appreciated Updated sat nav
Thank you RRSTDV8 pressing the land rover button on the fob has done the trick !! This forum is so valuable for new owners like myself, thank you each and everyone of you. Wayne. Updated sat nav
