![]() | Home > Maintenance & Modifications > Update Sat Nav |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
Its a 2009 according to his picture so it could be either a face lift or a mark 1 |
oops just noticed its a 3.0 so that's more than likely a hdd set up is it not |
Ha, yes!
Hazel Member Since: 23 Jul 2018 Location: Allendale Posts: 8 ![]() ![]() ![]() |
HI, sorry, profile pic was a default setting! It is a 2009 model.I'll take a look under seat.
If it is under the seat then the way I've found easier to switch DVD is to move seat up and forward as far as it'll go then reach your hand around to the front, slide the lock tab then press eject.
Thank you.Ill give that a go. |
This is the view under front seat. Is this it? |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Hazel, I have a 2009 facelift and the only way of updating the Satnav is by going to a Range rover dealer so that you can plug it into their computer and they will update it for you. There is NO Cd for this facelift.
Ah, righto. Won't pay dealer prices!!.
Not sure that is a sat nav unit what does your dash look like take a photo and show us as mine is a 2005 and looks nothing like that |
