![]() | Home > General > Very Steep Driveway |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1182 ![]() ![]() ![]() |
best solution is to put it in Low Range to reverse out |
KevAley Member Since: 22 Jul 2018 Location: East Midlands Posts: 2 ![]() ![]() ![]() |
Thanks very much, I will certainly give that a try |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Try reversing onto your drive so you can drive off forward. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Low range, as suggested. 2012 SDV6 - it's missing a couple of cylinders
Mine is on a short but steep drive. Never needed low range, even with the back seats down and a heavy load on board. I think I understand your problem in that I reverse up onto mine and drive forward out and you need to be fairly smart in coming off the gas and onto footbrake in order to stop the lurch forward in my case.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
^^^^^ This ![]() |
still, if it's really steep, just use low range, that's what it's there for --
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I had a situation many years ago with my Discovery 1 V8. I started the engine up in a confined area one morning from cold with the transfer case in low range. The brakes would not hold the car during the fast idle period when in reverse or drive. No problem when the brakes were warm and no fast idle. |
I would select the EPB, once that's applied feather the foot brake so that the EPB is holding the vehicle, then apply Park. That way the EPB takes the weight of the vehicle, not the Park pawl in the gearbox. Not sure how much difference it makes but it feels more sympathetic to me. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
That's what I was suggesting ? |
I would select park after releasing the footbrake, not before as you suggested (I think). 2012 SDV6 - it's missing a couple of cylinders
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
Definitely!
Copilot Member Since: 06 Jan 2014 Location: Sussex Posts: 31 ![]() ![]() ![]() |
Further to the other replies already offered...
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 ![]() ![]() ![]() |
Try parking sideways. Rolling sideways off the drive would be so much cooler. Noisy black one |
