Home > Faults & Fixes > Rear door Lock Doesnt open door from key
mrluke
Hi ,
Seems my rear passenger door lock doesnt seem to open with a single press of the key (2012 RRS) , From what i can see looks like it doesn't go fully down .
If i use the unlock button inside or press the key again it unlocks fine.
All other doors seem fine tbh and just seems to be this one .
I have two stage locking/Unlocking disabled , and was wondering what else it could be other than replacing maybe the door latch ?
Thanks
Luke
Post #561672 Fri Jul 20 2018 8:33am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Luke
I replaced the left hand rear door lock in my friends Discovery 3 a few years ago for the same problem. It would not lock from the fob but would unlock if the door had been locked manually. On that basis I think you need to replace the door latch/central door locking assembly. Key to replacing the assembly is removing the outer door handle. From memory the rear of the door handle is attached via screw which is easily removed (once the cap at the rear of the handle is removed). The front end of the handle is attached via a splayed lug. To release this splayed lug there is a centre peg which needs pushing out - from memory I pushed from the inside of the door.
Without removing the outer door handle I could see no way of releasing the linkage from the outer door handle release to the latch/lock assembly. I did not need to separate the door wind regulator from the window.
I am assuming the method that I used is applicable the to the RRS which is based on the Discovery.
Note it is likely that you will break the clips of the rear cap of the door handle when you try to remove it - ie it will need to be replaced.
Post #563955 Sun Aug 26 2018 10:08am
mrluke
Thanks for that info, Much appreciated ! I am now awaiting my replacement door lock.
I actually bought replacement motors for the oem part but will fit a replacement part and repair the door lock after as a spare Wink
Thanks
Luke
Post #568587 Fri Nov 09 2018 8:57am
J.Prezes
Poland 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Or you can do this:
https://www.disco3.co.uk/forum/door-lock-m...ight=latch
For me (on 08 disco) )it didn't help so I've bought new motors and whenever time allows will change them.
Post #568809 Mon Nov 12 2018 8:54pm
