Home > Technical > Creaking Suspension
Hope1979
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Creaking Suspension
RRS HSE 2011 Auto with 140,000 miles.
I bought this car back in October and not really had any major issse with it so far.
It has developed a creaking noise when going over bumps both at low speed and high. the vibration of the creak can aslo be felt through the steering wheel. this only occurs when the vehicle has warmed up over 30 mins of driving. It sounds as though it comes from the front but not sure which side. it also creaks when lowering and lifting the car to the differnet suspension hieghts (hopefully video link works)
I had the car in at my usual independant for service/MOT/Gearbox flush (slugish gear change, problem solved) but they couldn't replicate the creak but also could not see anything obvious.
Grateful for any advice and if thee is anything i can easliy do to narrow down the fault.
THanks
Post #561315 Fri Jul 13 2018 9:23am
Brit Plumber
Are you raising and lowering in park only? Or with foot on the brake? Or handbrake on? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #561316 Fri Jul 13 2018 10:43am
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
ARB
Bushes by the sounds of it mine (front) have been replaced under warranty as they were only done last March by an indy. I don’t think they were cleaned and lubed properly on replacement Censored
Post #561317 Fri Jul 13 2018 11:34am
Hope1979
tried in both. first half the video is with the operated in park from within the vehicle second with the handbrake applied operated form outside. irrespective onf the brake aplication, the smae sound is heard when driving over bumps
Post #561321 Fri Jul 13 2018 12:55pm
Hope1979
Post #561322 Fri Jul 13 2018 12:57pm
micknolan
Sounds like what I’m having, also the same as others with bushes drying out in heat.
Only happened since the good weather.
Have tried spraying with silicone spray only fixes it for few hours.
Post #561326 Fri Jul 13 2018 2:31pm
Cymruambyth
Wales
^^^^^^ This. Or wait for lots of rain.
Same noise as mine. Steve.
Post #561327 Fri Jul 13 2018 4:08pm
Tyrefitter
Mine as also started creaking since the hot weather.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #561332 Fri Jul 13 2018 5:25pm
Themoog
And ours.. my X5 did it too last year but for some reason not this year.
Post #561363 Sat Jul 14 2018 11:46am
mlambton
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Mine is a 2010 RR Sport with 62k and makes the same noise in the summer. sounds like a wwII tank at low speed. My ARB bushes are 1 year/6k old too.
Post #565350 Tue Sep 18 2018 11:05am
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I bit the bullet and had the bushes replaced, got my sanity back! 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #565351 Tue Sep 18 2018 11:55am
mlambton
Eventually the creaking and groaning became so embarrassing i had the ARB bushes changed out today. The parts are only £20 plus of course 90 mins labour but at last the suspension is quiet once more....steering and handling definitely a little sharper too
Post #605851 Thu Oct 22 2020 5:35pm
Puslinch
Not much to pay for peace and quiet! 2018 Telsa MS
1990 Porsche 944
Post #605852 Thu Oct 22 2020 6:07pm
