Home > General (L494) > Anyone hardwired a dashcam in L494? |
PDC Member Since: 13 Dec 2015 Location: Warwickshire Posts: 163 |
Hi ARWV8, Did you manage to get all of your gubbins behind the glovebox out of sight rather than having to installing it in the glovebox because of the lack of space. Cheers, Paul. 2010 RR 5.0 Autobiography 2020 F-Pace SV 2018 RRS HSE Dynamic 3.0 2015 Disco XXV 2011 Disco 3.0 2008 RRS HST V8 |
Wed May 02 2018 8:54pm |
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 |
Not sure as did not see him do it. However I know he had to use a fish wire to do some of it and he said it was awkward. He drilled a hole in the trim to feed wire to camera and put a rubber grommet in the drilled hole. |
Thu May 03 2018 11:44am |
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 |
Audiofile-InCar in Bishops Stortford do a lot of these installs and have some cool sample work of what they've done - will be booking my car in for one.
Thu May 03 2018 1:07pm |
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 101 |
Gotcha, thanks. Thats what I suspected. |
Thu May 03 2018 7:31pm |
arwV8 Member Since: 17 Feb 2018 Location: Worcestershire Posts: 18 |
Hi PDC, apologies for the delay in responding, been off the grid for a while.
Sat Jun 16 2018 2:35pm |
Hi arwV8,
Thu Jun 21 2018 10:24pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
I went for the installation in the rear boot fuse box. Have run the cables to front down the right havd side of the car and then will run down the left habd side for the rear camera.
Sat Jul 07 2018 8:04am |
I will be probing around with a Digital Volt meter as I'm going to put a rear cam in to. Autonomous one though as can get a 10hr + loop on it as stand alone. There are so many options with the RRS, the fuse boxes seem to have some fits but not all , what I would call the max fit options but with blanks for the version purchased. the front fuse box has stuff marked NF, but there is a voltage there hence my earlier thread notes. Will post what I findings when my camera turns up and the install is planned. |
Sat Jul 07 2018 8:41pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1671 |
The power management unit does clever things so make sure you are testing long after the car has been locked and shutdown. I remember with my old HST the Tracker was initially connected to the power for the trailer plug. After 5 minutes of driving the power unit would realise no trailer was connected and turn off the power. |
Sat Jul 07 2018 10:10pm |
Good point Phil. I found the same when looking for power for dash cam on when ignition on only. and ignition +5 mins ish and so on, I found a node that stayed up for 15 to 20 minutes. |
Mon Jul 09 2018 2:47pm |
The wife had a new GPS tracker fitted (that tracks her driving for kilometre reimbursements) and the old one was not used. Since then my camera is now on long after ignition is switched off and also the 2 cigar lighter sockets that didn't work now do.
Fri Jul 27 2018 11:55am |
Hi All,
Tue Oct 09 2018 2:00pm |
ashie2 Member Since: 16 Jul 2020 Location: Cheshire Posts: 2 |
@philmw Please can you share with me too? In exactly the same predicament. Trying to hardware my BlackView
Thu Jul 16 2020 3:07pm |
