![]() | Home > General (L494) > Memory Seats Height Issue |
Do you press M then the memory number until you hear the gong and get a message in the dash screen? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
Yes, it confirms it with the sound and dash message. MY16 RRS 3.0 SDV6 HSE Dynamic |
Could it that you don’t use the same key fob every time then? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Nope - I only ever use the one fob.
Sounds like a trip to the dealers then...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
My seat doesn’t move when I stop the car, neither does the steering wheel. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
Have you tried turning off the auto mode for the steering wheel? That should stop the wheel and seat moving when you stop the car but you may still have a problem with the memory function.
Chips Member Since: 08 Nov 2017 Location: Shropshire Posts: 123 ![]() ![]() |
Not the same problem butI find quite often that if I only press the memory function once , it adjusts a little bit but no where near to where it should and doesn't move the wheel at all , however if I press it again and hold on the button it will go to the correct position . Just a landrover quirck |
ianmo Member Since: 08 Jan 2017 Location: Southampton Posts: 119 ![]() ![]() |
I had the same problem with my 17MY, dealer sorted it under warranty, but I think it's started again! |
Thanks for the tip on the steering wheel - it's a shame you can't change it so just the wheel moves and not the seat!
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
In the olden days, the pedals were adjustable and used to move out the way too.
Sorry no idea, it worked when it came out, that's all I know! |
