Home > Technical > Radar cruise control
LJRH
So I was on the m1 this morning with the CC set at 65 and I came to a gantry that was marked at 60.
The car put the brakes on- with no one in front of me! And slowed itself down to 60 and then carried on. Mind blown. I had no idea it did this?? Especially in a 2006? Noisy black one
Post #561001 Mon Jul 09 2018 2:13pm
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
This definitely doesn't happen on my 2012, if it can be enabled my mind will be blown also!
Post #561004 Mon Jul 09 2018 2:25pm
LJRH
I was very suprised. My route into work (south from Watford into London) doesn’t have any gantrys so I’ve never noticed it before and I don’t generally use cruise control. Noisy black one
Post #561010 Mon Jul 09 2018 2:33pm
geoffsnook
They dont as far as i am aware it only slows when it sees something in front if you have the radar system and when clear it speeds back to the original set speed Thumbs Up
Post #561012 Mon Jul 09 2018 2:56pm
LJRH
Unless it was the invisible man.. Noisy black one
Post #561016 Mon Jul 09 2018 3:13pm
geoffsnook
Rolling with laughter Rolling with laughter
Post #561019 Mon Jul 09 2018 3:22pm
On a similar note.
When driving on the motorway I sometime see a newish car (something German) keep putting its brake lights on.
It doesn't appear to slow down. I think its the active cruise control detecting a car infront.
If it is. What a bloody stupid and alarming system from someone following. Hope the RRS don't do this
Post #561046 Mon Jul 09 2018 9:22pm
geoffsnook
I assume it does put brake lights on as the active cruise really brakes hard if you get to close to a car in front Thumbs Up
Post #561051 Mon Jul 09 2018 9:40pm
Cymruambyth
Wales
Re: Radar cruise control
Mine doesn`t do that. Steve.
Post #561053 Mon Jul 09 2018 9:45pm
ilard
Andy K wrote:
On a similar note.
More likely a bad driver with an expensive annual brake bill. Adaptive cruise systems rely more engine braking / air resistance than constantly dabbing the brakes to stay within the distance window set by the driver. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #561081 Tue Jul 10 2018 8:01am
syl
I love the adaptive cruise control, but it does occasionally slow down “accidentally” when detecting a car in another lane, especially if there’s a bend and the car is actually a lorry. The active cruise control scores rather poorly on the driving statistics compared to a human driver. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #561085 Tue Jul 10 2018 9:03am
Brit Plumber
I quite like mine, I had a wagon swerve into my lane to miss a car that pulled out in front of him and the sport halved its speed in a milli second. Shocked me a bit at how quick it reacted. I also have the collision warning turned on and although it’s a little annoying at times it has alerted me on a couple of occasions when I’ve not been paying attention. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #561099 Tue Jul 10 2018 10:55am
Cymruambyth
Wales
My one gripe about it that it takes far too long getting back up to speed. Steve.
Post #561104 Tue Jul 10 2018 1:00pm
Andy K wrote:
On a similar note.
If the system applies the brakes then yes, the brake lights are illuminated. Which is a good thing as it means the following driver knows the vehicle is braking. 2012 SDV6 - it's missing a couple of cylinders
Post #561132 Tue Jul 10 2018 7:28pm
yeah but it didn't appear to slow down significantly.
And the brakes didn't stay on for long.
and on frequently.
I wonder if they were being lazy and cancelling cruise with the brake pedal.
But it appear automatic to me.
Sure if the car needs to brake hard, then the lights should come on, but this appeared minor slowing and a pain to show lights
Post #561151 Tue Jul 10 2018 9:40pm
