Home > Technical > AC condenser leak
camarados
Netherlands 2007 Range Rover Sport TDV8 HSE Orkney Grey
AC condenser leak
I was on vacation in France. Very hot .. and on the day of the way back I saw this pool of water next to the car.
This is the left front. Shocked
Turns out the air conditioning no longer functioned.
Do I have to go past the garage? And how long are they working on this when a leak is found?
Post #560994 Mon Jul 09 2018 12:01pm
geoffsnook
Not sure that's an ac leak that would only be the excess water that you sometimes get its a bit like condensation Thumbs Up
Post #560995 Mon Jul 09 2018 12:10pm
camarados
Ah, that would be better Smile
But it feels like whether the air conditioning works less well than before.
Post #560997 Mon Jul 09 2018 12:14pm
geoffsnook
Get a small thermometer and see what it actually says temperature wise when its set to the lowest i think they should get to about 5 degrees but maybe some gas as got out when was it last serviced the air-con Thumbs Up
Post #560999 Mon Jul 09 2018 12:22pm
Tim in Scotland
If it is very hot/ humid there is always a small pool of water under the car once you park up - the main thing is do you still get plenty of cold air from the vents, if so then it is normal if not then you need to get the car to an aircon service - car will be drivable BUT in hot weather not so pleasant with no cooling air inside. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #561027 Mon Jul 09 2018 4:07pm
