Home > In Car Electronics > 2011 SE Sport - Audio Options
bobsa31
I have a 2011 SE sport with Autobiography kit, it has Sat Nav and Harmon Kardon Sound system but no DAB, TV/DVD.
I had a Jaguar XF previously which had DAB fitted but wasn't working, I replaced the module and added a hybrid TV unit, coded it using SDD and it all worked. I would like to add, at least, the genuine DAB module, but possibly the TV and DVD units too.
I've had a look in the boot and can see the Bluetooth module on the MOST bus, however, can't see any other modules there that would accept further kit. on the jag there was what I assumed to be an amp that most other modules seemed to connect in to.
is there such a module for the RRS or do all the components wire back to the front with a separate loom?
thanks
Post #560774 Thu Jul 05 2018 12:44pm
geoffsnook
i too thought most of the parts went in to the rear right of the car you just buy them add it in to the most cable and enable in the ccf but there are usually lots of little bits to add like the Ariel and amp's etc but i am sure someone will come along shortly and tell you exactly what you need Thumbs Up
Post #560800 Thu Jul 05 2018 5:19pm
