![]() | Home > General (L494) > Roof bars again! |
Stiggy6767 Member Since: 05 Mar 2018 Location: Bolton Posts: 8 ![]() ![]() |
Apologies always sensible to read previous posts ! |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
They fit perfectly although the clamps are right at the end of the bars and could do with the next length up (mine are 135cm)
You are the man, thanks for that!
So, finally got a set of 150cm bars which work fine with the Evoque feet as described above;
tonyp Member Since: 02 Aug 2011 Location: Middlesex Posts: 15 ![]() ![]() ![]() |
Just to update this thread as Thule now have a kit that fits the early L494’s
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
I have just picked up a roof box, with -
Try here
I have have just a set of these delivered. They seem to fit really well, my only worry is the part that tucks under the roof edge above the doors may leave a mark. Anyone else use these? Did you fit some sort of rubber to protect them? John 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁 |
I had the same worry but was assured the clamp has an anti scratch coating. To be fair, I had mine on a few weeks and they didn’t mark the paint. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
I thought the same so I cut four short lengths of bicycle inner tube which I slide under the metal clips. |
Thanks for the replies 👍🏻 2016 Fuji White Autobiography SDV6 - Fully loaded with almost every extra! 😁 |
Pics of these fitted
Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101 ![]() |
Hoppy how did you get on using these with the Evoque parts? Any issues? I’ve a set off an old car and wondered if I should buy the Evoque feet or just suck it up and buy new Sport ones. It’s for a roof box and a long drive to France. TDV8 RRS HST in Java - Gone TDV6 RRS Autobiography in Bali blue - Gone TDV6 RRS Autobiography Dynamic - Current |
