Home > Technical > Whistling suspension?
RRS_FR
France
The car has developed an intermittent whistling / tweet noise coming from front offside
After a few mins the suspension fault warning light appears
The car rises and falls correctly and without time delay
Any ideas as my local Indy doesn't know or how to investigate
Apparently as the warning light is on it can't be a squeak relating to bushes?
Thumbs Up --------------------------------
2011 Autobiography, Fuji white, Le Mans interior
2006 HSE Black / beige 3 years from new
1986 RR Classic - metallic blue / grey - fantastic car
Post #560530 Tue Jul 03 2018 7:30am
Brit Plumber
Does the compressor continuously run? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560533 Tue Jul 03 2018 8:31am
geoffsnook
Get your indy to read the codes as there is a light on there will be a code Thumbs Up
Post #560538 Tue Jul 03 2018 9:11am
RRS_FR
France
How do I check re the compressor?
I understand it is not designed to run continuously as it will burn out
In the middle of France my indie although having built a jag rover to compete in the Dakar rally doesn't t have diagnostic tool! --------------------------------
Post #560559 Tue Jul 03 2018 11:19am
Front off side is where the front air suspension valve block is located. That'd be the first place to look if you can't do a code read. Check for leaks from the valve block and from the pipes connecting to it.
The valve block has three valves in it - one for each side (corner valve) and one that connects the two sides when required to allow for axle articulation (cross over valve).
Does the vehicle lower over night at all? A leaky corner valve or pipe would cause that, a leaky cross over valve wouldn't (as it would just allow air to move between the two non-leaking sides). A leak in a corner valve or pipe would cause the compressor to run pretty much constantly as well as cause the suspension to drop overnight.
If your garage doesn't have a diagnostic tool of some form then they shouldn't be touching one of these vehicles, to be honest. 2012 SDV6 - it's missing a couple of cylinders
Post #560593 Tue Jul 03 2018 4:53pm
RRS_FR
France
Update and thank you to all who helped!
It was a leak in the front balloon so we replaced the strut.
All good no more whistles ......
Apparently if an error light illuminates it is never anything to with bushes etc ,
Cheers --------------------------------
Post #563516 Sun Aug 19 2018 6:34pm
