Home > Technical > Air con problem? Strange one
ben_edwards30
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
I had my air con re gassed a couple of weeks ago all nice and cold but now it’s not really very cold at all. The strange thing is one of the rear vents is actually still quite cold. Colder than all the others anyway?
I’ve tried it on auto and having all three blowing options turned on but doesn’t seem to make any difference. Both temperatures are turned right down as well. Am I missing something?
Post #560380 Sun Jul 01 2018 2:10pm
DEVON
I’m no expert , but did they pressure test the system before re-gassing it ?
Had mine re-gassed yesterday and it actually took longer to do the tests than fill it with gas ?
Sounds like you may have a small leak somewhere , I’m sure someone more knowledgeable will
Be along soon Thumbs Up
Post #560384 Sun Jul 01 2018 3:38pm
ben_edwards30
I thought it would be a leak but the rear vent being cooler confused me a bit?
Post #560387 Sun Jul 01 2018 3:58pm
DEVON
That is strange ??
I suggest having it pressure tested first , I’m pretty sure they used some kind of dye in mine to test for any leaks in the system. But like I said I’m no expert, I just stood and watched Thumbs Up
Post #560389 Sun Jul 01 2018 4:51pm
geoffsnook
Had a similar problem with my other car a small Renault it took the air-con guy a while to find it was 2 small leaks so i would say get it checked it will more than likely be low gas Thumbs Up
Post #560404 Sun Jul 01 2018 7:41pm
Brit Plumber
Take it back as they have probably put a dye in it, then they can use the black light to find the leak. I think the cooler vent is probably a coincidence, try a thermometer on each one. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560410 Sun Jul 01 2018 8:48pm
