Home > Technical > Another issue.
Cymruambyth
Wales
Another issue.
My Sport has creaked a little since I`ve owned it, usually crawling over speed bumps or reversing up the drive...but very recently it`s got 100 times worse, to the point it`s just plain embarrassing to drive it. I`m convinced it`s since the wishbones were fitted but that doesn`t really make sense, maybe it`s just me. Is it likely to be some other bushes now? It`s on the front end too by the way. Steve.
Post #560115 Thu Jun 28 2018 10:06am
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
I posted a reply to this on another thread as I too have the squeaking suspension. I had it checked by my indi and they said front ARB bushes with surface rust caught up in them. The bushes are fine and don't need replacing but in this very hot weather will squeak and creak.
Last week I was up in the Lake District and we had some rain - squeaking stopped. Back home 85*F squeak is back.
Post #560120 Thu Jun 28 2018 10:58am
Cymruambyth
Wales
Really? Shocked Shocked Steve.
Post #560121 Thu Jun 28 2018 10:59am
Brit Plumber
Use a small spray bottle and spray a soapy water mix on to one bush at a time (match left to right) and after a few minutes to soak in, take it for a drive. Does it rattle rather than squeak? Is it only while straight or mainly when cornering? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560130 Thu Jun 28 2018 12:12pm
Rear hub bushes. 2012 SDV6 - it's missing a couple of cylinders
Post #560222 Thu Jun 28 2018 11:31pm
Eaters
WD 40 on the ARB bushes sorted mine - see the second part of this post:
http://www.rrsport.co.uk/forum/topic51392.html
I have a theory that the hot weather accentuates the problem (with acknowledgement to LandPhil) Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #560227 Fri Jun 29 2018 7:03am
Cymruambyth
Wales
It`s more of a creak and it does it as I`m driving along...constantly. Steve.
Post #560233 Fri Jun 29 2018 9:20am
Cymruambyth
Wales
RRSTDV8 wrote:
Rear hub bushes.
Pretty sure it`s coming from the front. Steve.
Post #560234 Fri Jun 29 2018 9:20am
Cymruambyth
Wales
It`s going into the garage next week to have my suspension issue looked at so I`ll get him to do the WD while it`s there Thumbs Up Steve.
Post #560235 Fri Jun 29 2018 9:21am
Eaters
I’d be tempted to put money on it thst it’s the ARB bushes. My squeaking was just the same whilst moving along. The slightest bump would set them off. I reckon that the WD will fix it. Or a good rain storm😀. But not much chance of that for you with Porthmadog being the warmest place in the UK☀️ Robin
Gone:
MGZTT 190 2.5
Post #560236 Fri Jun 29 2018 9:27am
Cymruambyth
Wales
Laughing Yeah no chance of a downpour for quite a while.......reminds me of the Summers I had as a kid Very Happy Very Happy Steve.
Post #560237 Fri Jun 29 2018 9:29am
Brit Plumber
I thought you had to be careful with WD40 as it can eventually break the rubber down. 2019 5.0 SC SVA (Current)
Post #560241 Fri Jun 29 2018 10:49am
LandPhil
I wouldn't use oil or WD 40 on the bushes. Get a silicon based lubricant, Halfords do one, that will not harm the rubber.
Post #560243 Fri Jun 29 2018 11:53am
Cymruambyth
Wales
Thanks for the advice and the tip on WD guys Thumbs Up
I googled it and WD can break down rubber over time. Found it on a boating forum Laughing Steve.
Post #560256 Fri Jun 29 2018 3:19pm
Cymruambyth
Wales
Just been shopping and there wasn't a peep from underneath...not a sound, drove lovely....coming home, about quarter mile away and it started again....sooo annoying. Sounded like the rear this time, god knows. Sounded like a bag of Censored . I'll get some silicone spray and see if that sorts it as suggested. Steve.
Post #560278 Fri Jun 29 2018 7:38pm
