![]() | Home > In Car Electronics > reverse camera |
Grizzly_Al Member Since: 10 Jun 2017 Location: Farnborough Posts: 15 ![]() ![]() ![]() |
Hi all,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Quite a common fault on the earlier face-lifts, I think you may find you need a replacement camera. You won't have "bendy" yellow lines either unless you have the surround camera system fitted.
Cheers for that,
You shouldn't need to programme a new camera, but make sure you get the correct one as there are two different one's, although identical to look at, the standard camera has a 2 pins and a co-ax connection, the surround one has 4 pins and they are not interchangeable.
awesome, thanks for that
