Home > Technical > Parking sensors
ben_edwards30
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
Parking sensors
Hi. I have a 2007 rrs. It has had an autobiography conversion already done when I bought the car.
The parking sensors don’t work. Just a long beep when selsecting reverse. None of the sensors click when listening to them. I pulled back the rear bumper and the loom all seems to be plugged in and wired up. Does anyone have an idea where to start with fixing the problem? I was expecting the loom not to have been converted so I’m not sure now.
Post #559674 Sun Jun 24 2018 7:48am
ben_edwards30
I had it scanned yesterday and this is the fault I got:
U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message
Post #559675 Sun Jun 24 2018 7:49am
ben_edwards30
Also I’m not sure if the headlight washers are working either? Not sure if that’s linked somehow?
Post #559676 Sun Jun 24 2018 7:50am
Front sensors also need to be ok for the rears to work.
Do you have an IID ? You could disable the fronts in car config and unplug them under drivers headlight and see if rears work.
Or if iid you can measure the distance each sensor reads.
Otherwise remove front bumper.
And maybe purchase a sensor or two off eBay.
The long tone does point more to a rear failure. Maybe a rear sensor has gone.
Park brake needs to be off to listen to sensors. So park on level ground
Post #559686 Sun Jun 24 2018 9:54am
ben_edwards30
iid? I that a code reader? If so then no I don’t sorry.
My brothers breaking a 2006 rrs so I’ll borrow a few bits from that and see if I can eliminate the problem. I could possibly see f a friend will plug it in a see what he can read from it.
Post #559688 Sun Jun 24 2018 9:59am
ben_edwards30
I didn’t know the parking brake had to be off either. I’ll have another check. Thanks.
Post #559689 Sun Jun 24 2018 9:59am
ben_edwards30
I just tested it with the parking brake off and they all click except one on the rear. Would one not working cause them to not work?
Post #559691 Sun Jun 24 2018 10:41am
ben_edwards30
Would an outside sensor be an angled one or a straight one??
Post #559693 Sun Jun 24 2018 11:10am
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Angled!
Post #559702 Sun Jun 24 2018 1:07pm
One faulty can stop them all
Post #559753 Sun Jun 24 2018 6:25pm
