Home > Technical > Squeaky suspension
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Squeaky suspension
So I noticed yesterday that my rr sport seemed to have developed a squeaky/groan when going onto my drive. Got up today and it had stopped but after about 5 miles it reappeared so looks like it comes and goes with warming it up. I have warranty through Land Rover but do you think it will be covered? Any ideas on what it might be? The rear ARB bushes have been replaced so doubt it’s them and it was quite squeaky when lowering to access mode
Post #559578 Fri Jun 22 2018 7:53pm
Rear hub bush makes a squeak when it's ready for replacement. That's the one that connects rear upright/hub to the suspension arms. Unlikely to be covered by LR warranty, sadly. Luckily, however, it's not an expensive job at a decent indy. 2012 SDV6 - it's missing a couple of cylinders
Post #559579 Fri Jun 22 2018 8:23pm
scousefly
Would they
Just change the Bush? Would it be prudent to get both done? Obvs dependant on price. What are dealers usually like if they diagnose but you decide to go elsewhere would they charge?
Post #559583 Fri Jun 22 2018 9:33pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
I have the same problem and it has been diagnosed by my Indy as the front ARB bushes. They squeak when surface rust gets caught in the bush. My bushes don’t need replacing but that is all that will get rid of the problem. The Indy lubricated them with a silicon lube and the noise disappeared for a couple of days. This hot weather doesn’t help either and if you drive through water it goes away.
When I’m back from my hols I will replace them.
Post #559625 Sat Jun 23 2018 2:46pm
scousefly
Deffo
Not my front ARB bushes. All ARB bushes have been recently replaced
Post #559628 Sat Jun 23 2018 3:45pm
Easy way to check if it's a rear hub bush is to rock the car (reasonably vigorously) when it's sat on a level driveway. You'll hear the squeak and be able to pin point which side it is. 2012 SDV6 - it's missing a couple of cylinders
Post #559634 Sat Jun 23 2018 5:12pm
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Re: Would they
£156.00 for them to have a look at the fault MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #559637 Sat Jun 23 2018 5:36pm
scousefly
FFS
Censored Censored Censored Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Post #559671 Sun Jun 24 2018 7:32am
scousefly
Would it also
require a 4 wheel alignment if replaced?
Post #559672 Sun Jun 24 2018 7:42am
scousefly
So Dealer
says its the rear ARB bushes and as they are only just over a year old they will be replaced under warranty Thumbs Up Thumbs Up
Really surprised it was them as OEM was fitted last yr in March so wouldn't expect them to start squeaking so quickly, they were however fitted by an Indy so maybe there was something about the way they fitted them....who knows!!
Post #560055 Wed Jun 27 2018 6:55pm
Hmmm. I bet it still squeaks shortly after they do the ARB bushes... 2012 SDV6 - it's missing a couple of cylinders
Post #560072 Wed Jun 27 2018 9:12pm
