Home > Technical > Light Fittings In the Air Dam |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
On the L320, in the plastic air dam moulding under the front bumper there is a moulding on either side (under the fog lights) that looks as if it was designed to take a light of some description - I guess similar to what was fitted to HSE P38 Range Rovers.
Thu Jun 21 2018 5:19am |
Yes I have never seen a model with lights fitted but nevertheless the moulding is there - maybe a changed idea between design and production. Maybe that is where the fog lamps were originally supposed to be.
Thu Jun 21 2018 8:36am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Do you mean the bits that are moulded with a mesh design in the lower valance? On the SC and TDV8 the right hand one (when sat looking forward) is used for an auxiliary radiator air inlet. The SC was in the line up from the start so I doubt they had intended them to be for fog lights. 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 21 2018 9:03am |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
anything to do with these? http://duckworthparts.co.uk/landrover/copy...hting.html Merc C220 estate Sport AMG
Thu Jun 21 2018 9:55am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Thu Jun 21 2018 12:20pm |
bit of a difference in pricing there |
Thu Jun 21 2018 1:02pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
they make it look so obviously aftermarket fitment.
Thu Jun 21 2018 3:11pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
I think my SC has fake fog lights? Does anyone know? Can’t find a switch Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Thu Jun 21 2018 3:51pm |
There on the light switch you pull it out but you can't do it if the lights are on auto you have to turn it around to on if it has them |
Thu Jun 21 2018 4:07pm |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
BKHK, do these pics help?
Thu Jun 21 2018 7:55pm |
The cheaper set only fit only MY2005 to MY2009, the more expensive ones are for MY2010-2013 when the Car had a facelift. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Thu Jun 21 2018 11:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
The Adam Mesh ones are also not a genuine L/R accessory, although expensive do not include the genuine rip-off L/R price. I did have a RRS1 pre-facelift with the Mesh ones fitted and they were very good quality, perfect match and fit, far better than your usual cheap Chinese aftermarket crap.
Thu Jun 21 2018 11:44pm |
John
Thu Jun 21 2018 11:53pm |
We seem to have got off track onto aftermarket DRLs which is not the topic. I can buy those strip DRLs locally for less than about 10 pounds on ebay https://www.ebay.com.au/itm/2X-12V-8-LED-D...wYlRZNXCW.
Fri Jun 22 2018 1:27am |
