Home > Technical > Rear spoiler
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Rear spoiler
The top half ie the painted part of my rear spoiler is loose on passenger side of the car are there clips that can be replaced to secure this together
Thanks
Cosmo
Post #559534 Thu Jun 21 2018 7:03pm
There is one large black torx bolt either side. (I think you just open the glass hatch to see them.
Maybe the threaded clip rusted away on the spoiler
There are also some plastic nuts 3? when the tailgate is open
Post #559535 Thu Jun 21 2018 7:11pm
Cosmo15555
The problem is where the painted part meets the black part on outside corner in the picture
Post #559537 Thu Jun 21 2018 7:48pm
Better take it off to find out why.
I don't recall any clips.
Post #559542 Thu Jun 21 2018 8:32pm
Cosmo15555
Am I right in thinking if I needed to replace the camera or brake light you don’t separate the painted part from the black part
If not I might use some strong adhesive to bond the parts together without removing the spoiler
Post #559544 Thu Jun 21 2018 10:15pm
No you do not need to split the spoiler to change the camera or brake light, but obviously you do need to remove it from the vehicle to change either.
Post #559547 Thu Jun 21 2018 10:43pm
do you still have a 2006 car ?
Post #559567 Fri Jun 22 2018 8:43am
Cosmo15555
No I now have 2010 but forgot to change in my profile
Post #559569 Fri Jun 22 2018 9:28am
Cosmo15555
Just removed the spoiler and found the adhesive that holds the black part to the painted parts had come loose so I have used a strong adhesive to bond them back together
Thanks for the reply’s
Cosmo
Post #560323 Sat Jun 30 2018 4:28pm
Seepee3o
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Thanks Cosmo15555, my 2010 is the same with both half’s seeming to part - will apply the adhesive when it stops raining outside!
Post #611288 Wed Mar 10 2021 11:07am
Seepee3o
Well the adhesive I used was not strong enough! driving along at 50mph loud bang at the back as the spoiler detached and blew off leaving (thankfully) the camera dangling on the rear windscreen on its cable. Phoned Duckworth LR at Market Rasen who said pop down for a look. They inspected it, ordered a new spoiler under warranty (This is a 2010 RRS!) Spoiler currently being painted should get it fixed this week with new adhesive as per the recent recall - all FOC Very Happy 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it
Post #623214 Tue Mar 29 2022 1:30pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
As mentioned, this problem has been the subject of a recall for some time now.
Contact your nearest dealer for a free check-up and fix.
Post #623216 Tue Mar 29 2022 2:19pm
