Home > Faults & Fixes > IIDtool Height sensor Calibration failure |
johnsporttdv8 Member Since: 02 Nov 2014 Location: Cambridgeshire Posts: 16 |
Hi all.
Sun Jun 17 2018 12:43am |
I have the same tool but not needed to do the cal yet. It sounds like it has updated the settings but the settings were to far out and maybe then given you a fail. So maybe not a fail to update but the update has led to a fail. Did you save the original file? Have you tried re calibrating with new calculations? Did you use the guide on the GAP website?
Sun Jun 17 2018 8:22am |
Thank you for your thoughts Brit plumber.
Mon Jun 18 2018 8:43am |
So when you first plugged in your IDD tool it would have saved the original setting's you can reset every thing back to it was as long as there were no original faults as they would also be put back you can try this or you can email pat at gap as they would be able to help and yes i would have thought if you just tried to set the one new ride sensor first before trying to reset all four it may be the right way to do it but i may be wrong |
Mon Jun 18 2018 9:36am |
Thanks.
Mon Jun 18 2018 9:53am |
Just log in to your account and then use the contact form |
Mon Jun 18 2018 10:46am |
Sorry go through support then contact |
Mon Jun 18 2018 10:47am |
Have emailed Gap and they are now talking to me.
Mon Jun 18 2018 8:26pm |
This has been an interesting thread and saved me a future question. Hopefully it will all be a sorted soon!! 2019 5.0 SC SVA (Current)
Mon Jun 18 2018 8:28pm |
duckboy74 Member Since: 10 Dec 2015 Location: Pasadena, CA Posts: 6 |
I get "Operation Failed E40" and "E41".
Thu Jun 28 2018 10:15pm |
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 |
Pat will get you sorted, he’s very good and gets back to you really quickly... last time I needed to update new version when I got an error. ____________________
Fri Jun 29 2018 4:08pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
maybe you need to configure the new height sensor in the CCF first RRS 3.0 SDV6 HSE Lux
Fri Jun 29 2018 9:05pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
You have a fault with the rear left sensor too, going by those readings... |
Sat Jun 30 2018 7:38am |
