Home > Technical > Parking brake shreik
d-9
Parked up outside the pub and there was a loud shreik and the dash came up with parking brake malfunction. Obviously I went for a pint and ignored it, when I got back it seems to work perfectly again.
Any idea what causes this? Should I strip the epb?
Post #559246 Sun Jun 17 2018 11:08pm
geoffsnook
Clean and adjust the handbrake shoes as soon as you can Thumbs Up
Post #559253 Mon Jun 18 2018 7:17am
Oldandconfused
And probably best not to use it until you do or it may damage the module. Put a bit of tape over the switch, you will be surprised at how you automatically go to apply it.
Post #559257 Mon Jun 18 2018 7:37am
gogsy1956
I completely agree with the previous comments,,, get the rear brakes serviced ASAP or it will cost you dearly. Lots of threads on this subject on here if you search. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #559296 Mon Jun 18 2018 6:02pm
d-9
Rear shoes and fitting kit are a couple of months old and it's not been through mud since they went on, so I'm fairly sure everything is OK inside. My question was more around which part makes the shreik noise and if it's a sign I need to tighten up the shoes, or if its the module that needs stripping and cleaning.
Post #559318 Mon Jun 18 2018 9:37pm
gogsy1956
My indie told me dirt / brake dust is the arch enemy on these systems and advised that they are stripped and cleaned / lubricated on a regular basis, they also have to be adjusted correctly then they will be fine. The module is quite well sealed and I don't think there is any chance of anything getting inside, probably has more chance of being worn, then again, badly adjusted / dirty shoes will will only help cause issues with the module and cables. 2010 RRS, TDV8
22" overfinch
Post #559380 Tue Jun 19 2018 5:09pm
