Home > General > Mirror dip + tyre pressure |
Left mirror only dips and I run my 22s at the same pressure as the 20s which I think is recommended by most vendors. 2019 5.0 SC SVA (Current)
Sun Jun 17 2018 2:56pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
Thanksmate and 33psi all round? |
Sun Jun 17 2018 3:04pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Both mirrors dip on mine and I keep at least 38psi in my 22's 2010 RRS, TDV8
Sun Jun 17 2018 5:25pm |
Interesting... mine both used to dip but only one now
Sun Jun 17 2018 6:36pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
2010 RRS, both mirrors will dip, but I have set them so that only the NS one actually moves (so I can see the kerb). From memory you have to turn the reverse mirror dip on in the menu and when in reverse, set them to where you want them-best check your hand book though |
Sun Jun 17 2018 7:04pm |
Had a play with my mirrors today and found that both do adjust for reverse but my drivers side was just set at the same position for forward and back. 2019 5.0 SC SVA (Current)
Tue Jun 19 2018 12:43pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
You can change the angle to suit when you reverse. Steve. |
Tue Jun 19 2018 4:40pm |
What threw me was that only my passenger moved in reverse. It never occurred to me that the previous owner had never set the drivers side to dip (probably didn’t need to as I’ve found). So apologies to the OP for my response (2nd down from top ) stating only the pass dipped. I’ve learnt something new (again). 2019 5.0 SC SVA (Current)
Tue Jun 19 2018 5:49pm |
