Home > Technical > camshaft sproget
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
camshaft sproget
Could any one tell me how the rear camshaft sprocket lines up on the camshaft on a rrs 3.0 Rolling Eyes
Thanks
Post #559152 Sat Jun 16 2018 6:51pm
Disco_Mikey
Has a key way. Only fits one way...
Post #559154 Sat Jun 16 2018 7:11pm
blueiceplus
camshaft sprocket
thanks but I've took the 3 bolts out, and the pulley back part is still bolted to the camshaft by the centre bolt and the pulley will fit in 3 different position and the manual doesn't say.
Post #559158 Sat Jun 16 2018 7:50pm
Disco_Mikey
Why was the pulley removed? Confused
With the cam locked in position, the mark on the pulley goes to the 10/11 o’clock position (as viewed from the rear of the engine)
Will get it close enough at that to retime the pump Thumbs Up
Post #559167 Sun Jun 17 2018 6:18am
blueiceplus
Thanks for your help, I'm still a bit confused about how to lock the camshaft in position, I will look at the manual, I have noted today that the part on the camshaft as an arrow on it, and I know that the sprocket as a marker line on it, should they line up Exclamation To cars had a small battery fire, and the belt cover is one of the parts that I've changed.
Thanks again
Post #559205 Sun Jun 17 2018 2:28pm
Brit Plumber
If you didn’t lock the cam shaft, I’d be a little worried that your timing will be out. Have you disassembled the belt, pulley and tensioner? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #559211 Sun Jun 17 2018 3:01pm
Disco_Mikey
https://www.instagram.com/p/BiWWpH9g2Sp/?u...8g8slxqzlt
2nd photo. Can't seem to save it to upload here Thumbs Up
Post #559216 Sun Jun 17 2018 3:52pm
