![]() | Home > Maintenance & Modifications > Electrical gremlin or easy fix |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Short journeys and infrequent use won't be very good for your battery. As a relatively cheap start, I would splash out on a Ctek battery charger, give it a recondition and then a top up every so often. If you have 13 pin tow electrics (white plug under tow cover) and park it off road, you can get an adapter and leave it plugged in to charge overnight.
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 ![]() ![]() ![]() |
Thanks for your reply. The suspension issue came before the battery issue quite a while before. I’ve had it plugged in and the nsf height sensor was the fault. It just seems strange that now the battery has been flat twice and the radio keeps going in to low power mode even though the car is running ? |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Low Batteries can cause all sorts of strange errors and problems. Its a good idea to make sure that your electrics are in good health before starting to spend too much money elsewhere. So check the battery and as Oldandconfused says, give it a good charge. If it is old it may well need replacing and if it is relatively new, get the alternator checked. Other things that have been reported here are the brake light switch (easy and cheap to replace) and make sure you have good quality bulbs in the rear lights - especially brake lights. Yes, I know it sounds screwy but weird faults have been reported fixed by replacing a faulty bulb. Of course it could still be suspension especially as you have a code that confirms it but checking the battery and alternator costs little to nothing so may be worth a try anyway. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Just checked the battery & alternator. Alternator is spot on but battery that is an 830 is at about 538 and it said it’s 48%. It’s date was 08-04-17 so only a year old. Had it fitted bout 6/8 months ago. My mate who fitted it at his garage is just going to replace under warranty. Still think the height sensor needs changing so I’ll get that done too ! |
So I had the height sensor replaced and that fault has gone.
Sorry to bump but can anyone help ?
Sorry that no one else has come forward but if you can put up with my musings a bit more...
Thank u for the reply !
Just found something about the upper tail gate switch being faulty can cause battery drain??? Is this right ???
Aha!
I’ve ordered a new switch.
