Home > Technical > Rear window wiper
Dylan
England 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Rear window wiper
Hi my rear wiper stopped working but my washer jet is ok . Have checked motor seems fine but have no power getting to it . Could anyone advise
Thanks
Post #558954 Thu Jun 14 2018 4:50pm
the early models have a relay behind the left light. (inside)
check power there.
or wires get broken going into the tailgate
Post #558957 Thu Jun 14 2018 4:57pm
Dylan
Hi thank you for the reply my rrs is a 2010 facelift .the wiper was working then one day it didn't work then about 20 mins into journey it worked but then didn't work again
Post #558961 Thu Jun 14 2018 5:18pm
Brit Plumber
Still worth testing the wiring between body and boot. I had a problem with a BMW where the locks would lock on command but then unlock seconds later. I found that 2 wires had shorted to each other at the point the look hinged. I ended up replacing all the wires at that point as 2 more had split. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #558974 Thu Jun 14 2018 6:31pm
Dylan
Thanks for that I will have a look at the weekend
Post #558976 Thu Jun 14 2018 7:02pm
Dylan
I have had a diag tool on this and it says open circuit on relay but can anyone tell me the location of it
Post #562090 Fri Jul 27 2018 12:30am
Would appear to still be behind L/H trim panel in boot.
Description: Relay-Trailer-Rear wiper
Post #562091 Fri Jul 27 2018 2:00am
Dylan
Many thanks for that I will have a look
Post #562093 Fri Jul 27 2018 4:54am
Dylan
Hi all sorry for the delay . I finally managed to get my rear wiper working . The Venter shaft on motor was a bit tight so freed that and was a loose connection on relay so happy days . The relay was as you said behind left panel in boot. Thanks everyone for your help
Post #566688 Thu Oct 11 2018 2:12pm
Dylan
Sorry center shaft
Post #566689 Thu Oct 11 2018 2:13pm
