![]() | Home > In Car Electronics > USB flash drive |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
try a different flash drive... |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
I just purchased this 1 which is a sandisk
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
if standard system then think single folder with all MP3 files in
Thanks for your reply when I formatted the drive I did quick format so I have just started a full format then I will put 2 files on with one of them in a folder and see what happens |
another option is to try a smaller flash drive, say a 4gb and see if that works....i've never used anything bigger than that so it could be that the 32gb is to big.. |
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 ![]() ![]() ![]() |
hi..i some where read about the radio only reads upto a certain amount of gb size usb i think the max was 4 or 8 gb
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
The max size it will read is 32gb as I have used this size, however I think it has to be ExFat format not Fat32.
I have tried formatting to ex/fat but still not reading so will get a 4gb to try
Not saying it's the problem but might be worth checking the lead that goes from USB socket through the cubby box lid into the harness, as these have been known to break a wire with continual opening and closing the lid. Not sure what the symptoms would be if the lead was broken as regards to screen message though. Do you by any chance have a USB socket under the flap by the rear air vents between the front seats ?, if so could try a drive in there as might prove something.
i think the newer rrs can support 32gb ...any ways can you let us know the out come when you sorted it.
I spoke to rangerover dealer yesterday they said poss problem with usb interface but want to charge me an hours labour to check it out
wow there cheeky.
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
Occasionally my 32gb USB takes a while to connect. Leave it a bit longer & see if it connects. I'm not sure if it's related to the amount of info on the USB stick? I've got loads of music on mine. I'm in the shed, I'll be back in the real world in a minute.
I tried leaving it to connect for about 20 minutes but still not connecting
