Home > Maintenance & Modifications > Wing Mirror Indicators and DRLs |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
I have a 07MY RRS TDV6
Fri Jun 08 2018 2:04am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4986 |
Not thinking of these by any chance are you ?.
Fri Jun 08 2018 4:38am |
Hi Col - I think that is it - thanks for that.
Fri Jun 08 2018 8:28am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4967 |
DRL's that go in the fog lights are usually a ring, so its obvious its a DRL not fog. |
Fri Jun 08 2018 10:43am |
Fri Jun 08 2018 11:02am |
Thanks for the link - So you basically built a kit from scratch - I take it that you did not find a kit to do what you built?
Fri Jun 08 2018 12:22pm |
Thanks - great information. I am not after anything other than simple DRLs - when engine is running with lights off the DRLs are on and when headlights are on then the DRLS are off.
Fri Jun 08 2018 2:02pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
Be aware that if you use a DRL controller that uses a voltage sensing relay to switch on the DRL lamps then when you plug a battery charger in the DRL lamps will light up when the voltage at the battery terminals exceeds just over 13 volts. |
Fri Jun 08 2018 5:08pm |
