![]() | Home > In Car Electronics > Thinkware F770 dashcam hardwire via overhead console. |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
There has been many forum discussions regarding hardwiring of dashcams via the fuse box with some very helpful info and photos but I am considering using the overhead console power supply method which there is not much info about on the forum.
Bump |
http://www.rangerovers.net/forum/9-range-r...ector.html
Thank you Lindap and Paddi for your replies |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
I don't know if it will be there unless you have a sunroof, but have a look for a light grey unused 10pin multi connector in the roof space by the overhead console, it is used for the sunroof motor/module. If it is there, check pin No.1 should be a Brown and Red wire which is battery feed to the motor, I really wouldn't know, if it is a permanent live or not but might be worth checking, might also need to check if there is a fuse in position 47 (20amp) in the passengers side fuse box to make it live whether permanent or aux. in either case. As I said don't know one way or the other just a suggestion, I do have a sunroof and when get a few spare minutes will have a look at mine to check if its permanent live or not
Hi Col,
Steve,
Hi Col,
Hi Col, Just checked what plugs and cables I have tucked up in my roof headlining! I found this unused plug 'lurking' above the headlining on the passenger side. It looks like the sunroof plug you mentioned? ![]() ![]() ![]() ![]() ![]() Is that the right plug? Would welcome your confirmation before I move forward with this solution ![]() Interestingly, Fuse 47 is present although I do not have a sunroof, so it must protect other accessories too ![]() ![]() If that is the right plug, it looks like you have solved the location of a permanent live above the overhead console ![]() Thanks Col Regards, Steve |
Hi Steve,
