![]() | Home > In Car Electronics > Options for fitting the likes of Apple Carplay? |
AlphaBravo Member Since: 30 Oct 2016 Location: Wirral Posts: 44 ![]() ![]() ![]() |
Hi guys,
https://www.aliexpress.com/item/Android-7-...39.99734.0
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
I have been looking for the same without any luck, if you do find something I would be very interested to hear about it. |
map_rrs Member Since: 30 Jan 2018 Location: London Posts: 32 ![]() ![]() ![]() |
Installing Apple CarPlay is on our list of tweaks - one of the forum sponsors (incartec.co.uk) has adaptor kits (fascia and wiring harnesses) here is the link: https://incartec.co.uk/Landrover/Range-Rover-Sport/ |
Bustanut Member Since: 19 Nov 2017 Location: Nottingham Posts: 71 ![]() ![]() ![]() |
Scrumpy, do you have a photo of your set up please. As your is the prefacelift I’m assuming you remove the lower stereo and keep the original screen. In the facelift versions there is not the option to do this. If anyone has managed it in a facelift RR please post details or photos. |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Hi Bustanut,
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hi AlphaBravo, I installed an 8.8" Android unit into my 2006 RRS, have a look here. I'd assume something similar could be done in the later 2010 RRS'. If you do go the Android route, make sure you get a head unit with at least 2GB RAM for smooth operation. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Morning Alpha.
RioRange Member Since: 22 Jun 2018 Location: Leeds Posts: 3 ![]() ![]() ![]() |
When you install these new head units do you still have access to all the aspect of the car i.e 4x4 display screen, diagnostics, TV? |
Bruce6571 Member Since: 28 May 2018 Location: Bristol Posts: 1 ![]() ![]() ![]() |
I have the same vehicle as the OP. And looking to do exactly the same also. The question is, as already asked, do these after market products still allow the use of all the existing cameras and diagnosis screen? Please. |
