Home > General > Has my RRS got air con?
airc909
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
sorry to ask what appears to be a simple question
but will my 2005 rrs 2.7 tdi se have air con?
i can't see the usual ice button anywhere
so it either doesnt have it, or it needs a regas as its not cold!
Post #558051 Sun Jun 03 2018 7:14pm
Stevepd
If it has it will have "auto" in the centre of the 3 dials and to switch it off on the bottom right hand side underneath the right hand dial it will say ECO. I'd post a photo but I'm on the iPad, somebody may be along shortly.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #558064 Sun Jun 03 2018 9:15pm
yeah it will.
the ECO button turns it off.
Post #558071 Sun Jun 03 2018 9:35pm
Tim in Scotland
It doesn’t just have aircon it has climate control......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #558081 Sun Jun 03 2018 11:07pm
d-9
Turn both temperature dials to lo, press auto. The fans should go flat out and after a while it should blow cold. If it's not cold in a couple of mins, something is wrong
Post #558084 Sun Jun 03 2018 11:35pm
airc909
cheers guys
Post #558098 Mon Jun 04 2018 10:17am
Tim in Scotland
If the system is working and doesn’t need re-gassing or overhauling then it is best to set it to auto and set both sides to 20 or 21 - this isn’t a temperature by the way according to Land Rover it is purely a numerical setting.......... - and then just adjust the setting up or down as you feel you need more warm or cooling. FYI the two sides/ controllers cannot be linked in L320 RRS so you cannot turn one controller and both side adjust at the same setting like VW/Audi and BMW systems . Running the system all the time has two advantages -it dehumidifies the interior and keeps the system pressurized and lubricated - it is thermostatic and will cut in and out as necessary to maintain the set temperature. You cannot adjust the humidity control. Running the system all the time has next to no effect on fuel consumption even with the 2.7 V6 motor. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #558100 Mon Jun 04 2018 10:37am
