![]() | Home > General > Steering vibration still |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
Wheel bearing track rod drop down link ball joint
dieselwoofer Member Since: 21 May 2018 Location: down south Posts: 23 ![]() ![]() |
It’s strange that nobody can find it. I was told all the suspension bushes were replaced a year before I brought it
Exceluk Member Since: 01 Mar 2013 Location: Nottingham Posts: 10 ![]() ![]() ![]() |
It’s defiantly a weird one.
Just remembered, I have a 57 TDV8, owned it for 6 years now but when i first had it had this strange vibration under acceleration when the steering wheel was turned slightly to the left, took it back to the dealers (under warranty) two days later they said it was a heat shield touching the column.... i still doubt that to this day but they did cure it whatever it was.
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
i suspect its your cheap davanti tyres that are the fault...get a 'road force' wheel balance and you'll see the difference or try a different set of wheels/tyres. |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
another potential issue is binding brake caliper.... |
[quote="scarey"]i suspect its your cheap davanti tyres that are the fault...get a 'road force' wheel balance and you'll see the difference or try a different set of wheels/tyres.[/quote]
[quote="PC76"]another potential issue is binding brake caliper....[/quote]new front calipers :thumbsup: 2011 RRS facelift |
