Home > General > Guess the quote! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The ebay sellers show the same arms for all versions of L320 RRS. My understanding looking at other sites is that there are differences between the TDV8 versions and others. At least, the TDV8 is usually shown at a slightly different price with a different part number. I would guess that the heavier engine means different bushes - the TDV8 has slightly different wheel alignment settings too, presumably for the same reason. 2012 SDV6 - it's missing a couple of cylinders
Wed May 30 2018 6:18pm |
Gibbro Member Since: 19 Feb 2018 Location: Bristol Posts: 14 |
It’s a 2009 model.
Wed May 30 2018 8:34pm |
You could use OE parts which are the same as LR but without the expensive logo / box. 2012 SDV6 - it's missing a couple of cylinders
Thu May 31 2018 11:03am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Check the policy, I have received quotes twice from warranty direct, the top policy says it does not cover suspension. MY12 RRS HSE Gone 4.2 supercharged RRS Gone 90 Gone s2000 |
Fri Jun 01 2018 8:29am |
Quote for the whole lot has come in at £3k from the independent. They're also going to see if the ARC actually needs changing with their MOT guy for me, fingers crossed they can knock another £1,500 off and just do the bushes.
Fri Jun 01 2018 8:37am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4996 |
garages don't like dash cams in their work shop.
Fri Jun 01 2018 10:59am |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
My nephew works in a MOT station, they have RR's in from local dealer ship for mot's, quite often he says they fail on the arc bar leaking. The cars come back within a hour having been rubbed down cleaned up, and its a pass! (not replaced) if its only a minor leak can it be managed? |
Sun Jun 03 2018 7:06am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4416 |
Or, some don't like recordings of inside their workshop, with all their expensive tools and equipment on display... |
Sun Jun 03 2018 6:18pm |
Update from the independent.
Tue Jun 05 2018 2:48pm |
