![]() | Home > General > Guess the quote! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Assuming they want to replace the rear anti roll bar as part of the work, then a main dealer is going to want at least £3k for that little lot.
Gibbro Member Since: 19 Feb 2018 Location: Bristol Posts: 14 ![]() ![]() ![]() |
Email has just hit me...not nice! All inclusive of fitting.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Technically, its an MOT fail...
![]() Gibbro |
They're now saying due to the age of the vehicle you can't get rear bushes only, needs to be the whole bar... walk away time?
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I`ve just had front lower wishbones replaced...£320 all in.
Has crossed my mind. Anyone know a good independent around Bristol? Gibbro |
bootneck99 Member Since: 25 Apr 2018 Location: somerset Posts: 8 ![]() ![]() |
Not in Bristol, but Ive used BG landrovers in Ross-On-Wye... |
If it's leaking then changing the bushes won't help, of course, but I don't believe them when they say the bushes are unavailable. Sounds like total BS to me. Edit: Advanced Factors show rear ARB bushes (with ACE a.k.a. dynamic response as fitted to your TDV8) for less than a tenner a pair. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed Last edited by RRSTDV8 on Wed May 30 2018 4:24pm. Edited 1 time in total |
The lower front arms are £150 each from Advanced Factors, the front ARB bushes are £16 a pair from the same place. Bolts are a few quid each as necessary. Brake pads at a main dealer is always silly money. Rear ARB - The bars are well over a grand each so this is not unexpected. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
And if the buyer asks "any problems you're aware of" then the price just comes down by the amount quoted for the job anyway. Say "no, mate" when you know otherwise (and they find out soon enough) and you're guilty of a crime. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
With that sort of bill and the potential savings, it'd be worth travelling a bit. You could pop along the M4 to Reading and try Rovertune - call them first and discuss the job / prices. Not used them myself but they've been recommended hereabouts before. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
![]() and if it took an hours labour I would be surprised. £100 £150 tops I wouldn't be rushing to replace the rear ARC bar if its a minor leak. (if it was a bad leak you would have a red suspension light on the dash). They all go at some point so no rush to replace unless the seals can be done to reduce cost or you are planning a road trip within a month or two |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Should’ve gone to Warranty [spec] Direct-avers...
