![]() | Home > Faults & Fixes > Front Right oil leak, suspect it’s ARB. |
Most likely, the DR pipes
Thanks for the fast reply, are the pipes in question the 2 pipes seen in the photos I’ve attached? I thought they looked quite corroded so wouldn’t be suprised.
It's a full day's work.
You were in deed spot on with your diagnosis. I took the wheel off and dried everything off. Started the car and after a while started with a weep at this body mount.
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 ![]() ![]() ![]() |
Wow for a 2012 model there is significant corrosion present? |
I think it’s pretty normal for a U.K. car that’s 6 years old. When I can get to it I’ll waxoyl the underdide as I’ve done with all my cars. The U.K. salted roads can make a real mess of the underside of a car, regular washing helps but it never stops. 2019 5.0 SC SVA (Current)
Parts ordered. £250 (VAT included), so just need to work out how much body lift is required and what I need to disconnect to achieve it. Luckily I dont need the car for about 10 days.
Happy to report all is fixed, now I just need to make a tool to bleed the ARB. I have a new filter for the valve block so I think I’ll do a full fluid flush front to back at the same time.
jimmybee Member Since: 11 Jul 2019 Location: Liverpool Posts: 3 ![]() ![]() ![]() |
did you have to have the body lifted? if so, what cost/time? |
The body should be lifted but I didn’t. I bought new pipes, did some measuring, some cutting, and used some 3000 Bar couplers to join the pipes back together. £250 for the pipes and £12 for the couplers. My local indie quoted £1200. It took me longer to get the under tray off than it did to fit the pipes!
Great job |
I would love to but it’s 18 months ago and I just went to my local hydraulic specialist with the pipe bore size and he produced these couplers from stock.
Ah, I didn't notice the dates on the posts |
No problem, hopefully others will find it a better option than lifting the body. If I hadn’t of bought the full pipe set, I would have just replaced the one pipe that had corroded. I also painted the pipes around the rubber insulators and put some grease on them (safe for rubber). 2019 5.0 SC SVA (Current)
