![]() | Home > General > Best engine |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Each engine has its own issues. The 3 litre diesels can have a crankshaft issue, the TDV8 can have turbo issues. Which diesel is having cracked blocks? 2012 SDV6 - it's missing a couple of cylinders
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1194 ![]() ![]() ![]() |
which problems, and on the L320 or L494? whatever you do, avoid the 3.0 diesel -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I thought there was less issue's with the 5.0 sc |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
Does that go for the sdv6 also |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
The 5.0 S/C is relatively problem-free and a superb engine to boot. |
SDV6 can have crank problems too but in the minority but if it goes it's still a new crank |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
3.0 since when ![]() ![]() ![]() My 3.0 L320 literally hassle free and anything I did have issues with was covered by the 2 yr used car warranty. So a bit liberal with that assumption, 3.0 litres are excellent in my opinion |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
if you are happy with petrol stick to it.
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
I have owned three 3Ltr V6s, one TDV6 and 2SDV6 and covered about 75000 miles in them and never had a single engine problem. |
I collected 5.0 s/c today and the performance is outstanding for such a heavy motor
I know what you mean, Cosmo.
I took out my friends son in mine last weekend and he thinks it’s similar performance to his mums Audi SQ5 but I’m convinced it’s quicker. 2019 5.0 SC SVA (Current)
