Home > General > Temperature gauge fault
Third gear
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
I have a fault with my temperature gauge. When I turn the ignition on the gauge instantly goes up to 1/3 when cold after I been driving it hits the top white line the obd is saying the temp is around 92 the radiator is not loosing water and 92 after a drive is probably ok . When I turn the ignition off the needle drops to 1/3 freezes for a second then goes the rest of the way down . Is this likely to be a problem with the gauge or sensor
Post #557523 Sun May 27 2018 11:11am
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Firstly I would swap out temp sensor
As this can cause the gauge to spike up and down No friends no favours
Post #557560 Mon May 28 2018 5:34am
Third gear
Thank you I give that a go first
Post #557604 Mon May 28 2018 6:46pm
