Home > General (L494) > Roof rails |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 |
The cross-bars will clamp to the genuine rails, using feet designed for that type of rail, no need for holes. I have the Thule cross bars and they are quite secure. MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
Tue May 22 2018 5:43am |
SCar24 Member Since: 08 May 2014 Location: United Kingdom Posts: 6 |
So you suggest removing the tabs on the cross bars, just using the actual clamping force to secure them? |
Tue May 22 2018 7:22am |
If your rails are not genuine or genuine-shaped, then sorry I cannot help you. For genuine rails here is a link to the Thule instructions for fitting the Thule feet to the RRS rails and Thule cross bars. Thule part number 4039 is the RRS specific feet.
Wed May 23 2018 12:09am |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
Wed May 23 2018 5:57pm |
Thanks PIG88, I had difficulty finding any info at all from LR on their cross-bars (as opposed to the roof rails) when I was looking around last year. Couldn't even find any LR cross-bars fitted to cars in their yard. Looks like I have not missed out on anything by not going with the LR ones MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
Thu May 24 2018 12:27am |
Thanks PIG88, figured there must be something like that. Seems I have aftermarket rails on my vehicle then, since I haven't got the holes you mention. Not sure whether to remove the tabs/lugs on the crossbars, or make an attempt to drill holes in the rails. Not exactly a flat surface Thanks again |
Thu May 24 2018 5:11am |
A few more thoughts . . . . Personally, I wouldn’t attempt to drill holes in the roof rails while they are in situ - too much risk of damaging your roof and very hard to get the drill in the right place. I would also be reluctant to try removing the lugs from the bars (could there be an insurance issue if your roof load comes off later and causes damage/injury?). An easier and better option may be to buy some Thule bars like the ones that GregP has and then sell the LR ones (e.g. on this forum). Similarly, you could swap the roof rails for some genuine LR ones although that would be more work and the old ones may be more difficult to sell. |
Thu May 24 2018 8:57am |
