Home > Technical > Ride height dimensions
Bulldog
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi
Anyone let me know what the recommended ride heights are for my 2010 RRS.
Need to change ride height sensor and I would like to check before and after as I’m sure a calibration will be needed
465 mm front
482 mm rear
Are these correct ?
Thanks
Post #556929 Sun May 20 2018 8:07am
SRE
Spain
I think you have Disco settings Whistle Whistle
Measurements are taken from the centre of the wheel to the bottom of the wheel arch.
Range Rover Sport
Standard ride height.
Front 461mm aim for a tolerance of +- 10mm
Rear 465mm aim for a tolerance of +- 10mm
Discovery 3
Front 466mm aim for a tolerance of +- 10mm
Rear 485mm aim for a tolerance of +- 10mm In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #556933 Sun May 20 2018 8:26am
Bulldog
Thanks that’s why I was asking for the correct settings as I wasn’t sure the ones I had were correct !!! Whistle
I also know where and how to measure them.
Thanks
Post #556935 Sun May 20 2018 8:48am
markg103
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Santorini Black
Hi all had the suspension apart and needs calibrating i have 22 in wheels would the ride height be calibrating the same IE roughly 462 front and rear l320 .
Regards mark
Post #599224 Sun May 24 2020 10:26am
Yes. Same as standard
461 F
465 R
Post #599225 Sun May 24 2020 11:12am
markg103
Many thanks Andy
Regards mark
Post #599227 Sun May 24 2020 11:29am
erickwan
Malaysia
Strange. My workshop manual says 462mm and 463mm, front and rear respectively.
Post #642144 Wed May 22 2024 8:33am
