Home > Faults & Fixes > 2007 RR sport loss of tv help
Tizzard
I’ve just come away in the car gone to put the tv on for the kids on the rear screens to find the tv option on the main display unit at the front has gone. Is there a fuse some where that could of gone or could it be the tv tuner? The options are there for the sat nav,Dvd,rear entertainment but no tv😬😬
Post #556895 Sat May 19 2018 12:53pm
Tizzard
Any1?? I’ve even tried searching to see where the fuses are for the tuner box and tv system and can not find anything😬😬
Post #556899 Sat May 19 2018 3:24pm
Tizzard
Bit of an update been this is what it brings up if I do a system check on the front screen
Post #556904 Sat May 19 2018 4:37pm
Tim in Scotland
Yours is a 2007 - the receiver/tuner may be an analogue one and since about 2010 we have only had digital signals for TV....... you may need a more modern digital tuner. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556907 Sat May 19 2018 5:08pm
Tizzard
It always worked fine since I brought the car as was last used a few weeks ago so can not seeing it being down to analog
Post #556925 Sun May 20 2018 8:39am
Try Fuse 58 10amp but I think if that was blown other things may not work either.
Post #556928 Sun May 20 2018 9:03am
Tizzard
Hi Col. I checked the fuse yesterday and was fine as it’s also the fuse for the main display up front. I didn’t no if there was a single fuse any where just for the tv tuner or something. As I don’t think it’s powerd up as it’s not showing the TV option on the main display
Post #556931 Sun May 20 2018 9:13am
Fault Code shown on the HLDF screen picture, might be worth checking co-ax cable has not become dislodged on either the tv tuner in the boot or the back of the nav screen. Only a cheap suggestion as not a audio/video engineer.
B100E25 Video Input "A" Television/Rear seat
entertainment video input
disconnected
TV/DVD malfunction
Check that the input is connected and that the system is
transmitting.
Post #556934 Sun May 20 2018 9:43am
Tim in Scotland
Are the connections to the antenna still all made at the rear side windows and the antennae on the glass still undamaged?
I cannot remember where the the player unit is located in L320 RRS (in my l322 FFRR’s the TV player was behind a panel in the boot) but have you checked that the antennae and power cable connections at the player unit are firmly home and that the unit is dry (condensation in L322’s was a problem if people didn’t use the aircon all the time). 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556937 Sun May 20 2018 9:50am
Tizzard
Everything seems as it should be. I’ve had the panel off and all the connections into the tuner seem fine. Orless the tuner is dead hence why I’m not getting the function on the main display up front for the tv option. Not sure it could be anything else as the DVD player works fine on the front and rear screens and the sat nav works fine🤔🤔
Post #557087 Mon May 21 2018 4:02pm
