![]() | Home > Faults & Fixes > P2098 and Hose info |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
Isn't that the battery vent pipe? It vents the hydrogen produced during charging away from the battery/fuse box etc. 2012 SDV6 - it's missing a couple of cylinders
austinsec Member Since: 16 May 2018 Location: Roslyn Posts: 4 ![]() ![]() ![]() |
Ok what do you recommend I do for the P2098 code |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Check around the throttle body/rear of plenum chamber for any loose pipes, not sure about the 4.4, but on the 4.2 there is an air pressure sensor that can blow off with age.
Ok, I have a 2007 RRS HSE , Throws code P2098 lean trim post cat bank 2.
