Home > Maintenance & Modifications > Possible air leak?
LJRH
Possible air leak?
Every few seconds something from driver front side goes pssshh. Not particularly loudly, but enough that you can hear it... air leak? Noisy black one
Post #556793 Fri May 18 2018 10:28am
Brit Plumber
Is your air compressor running at the same time? If not, I doubt it’s a leak, maybe something moving which sounds like a leak. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #556798 Fri May 18 2018 10:35am
LJRH
No my mechanic just noticed it when the car was sitting still on idle. We were actually trying to work out what the exhaust rattle was Rolling Eyes Noisy black one
Post #556800 Fri May 18 2018 10:37am
Socast
The valve block for the front suspension is in the offside front wheel arch so it will more than likely be the system self levelling. Mine usually hisses and clicks a couple of times after I park up.
Post #556817 Fri May 18 2018 12:07pm
LJRH
Thanks guys Noisy black one
Post #556892 Sat May 19 2018 11:19am
