![]() | Home > General (L494) > Aftermarket side steps....opinions please |
ianmo Member Since: 08 Jan 2017 Location: Southampton Posts: 119 ![]() ![]() |
I got my quicktread black side steps from JNK2000 Ltd, they have been on my RRS MY17 for nearly a year now and 40k, they still look good. |
Ratkat Member Since: 02 Oct 2017 Location: Wolverhampton Posts: 57 ![]() ![]() |
Cheers Ianmo, I will look them up. Did you fit them yourself? MY19 RRS Autobiography Dynamic 3.0 sdv6, Carpathian Grey, black pan roof, black pack, black 22’s, black side steps, ebony/ebony interior
bluestone Member Since: 11 Aug 2015 Location: Manchester Posts: 155 ![]() ![]() |
I bought some aftermarket fixed steps for £200. Cant remember where from but had them fitted by a friend in Manchester who owns an Audi workshop and it seemed fairly straightforward for someone with the correct tools.
andymc Member Since: 04 Jan 2017 Location: london Posts: 127 ![]() ![]() |
Urban Automotive so a 'black shadow' fixed sidestep for the L494 .... looks very cool and less than £500 SVR with a few bits from Urban and Glohh |
Raven8080 Member Since: 06 May 2018 Location: Bathgate Posts: 6 ![]() ![]() |
What did you end up going for? I'm on the lookout for a decent set. |
No I got the local indy to fit them for me. |
These are the ones I got & I removed the steel trims that are only riveted on & had them painted gloss black
Thanks |
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
How long does it take to fit side steps? |
Took me a couple of hours with it on a 4 poster lift,,their is a fair bit of cutting the plastic trims under car before you can bolt them on.
Thanks ...Andy Urban Automotive have told me their require no cutting of the sills and as per them neither do the genuine JLR side steps...anyone know? |
It’s not the sills that need cutting it’s the plastic under trays,,when I had my14 sdv6 ab which had steps fitted by main dealer,even they had to trim under trays to fit them.
OK, thanks much appreciated. |
The holes for fitting the steps are behind the trays so you have to cut them.if you have a look under the car it’s where the jacking point is,,that bracket comes off & the new one goes on which the steps fasten to
