Home > Wheels & Tyres > I think my speedo is out, help calculating correction please
Page 2 of 3 <123>
d-9
Does anyone else have a difference in reading between the speedo and cruise display?
My cruise display under reads, but the speedo is correct against GPS. E.g. 50mph on GPS is 50mph on speedo, but cruise thinks it's 53mph
Post #556311 Sun May 13 2018 7:19am
garrycol
Australia
garrycol wrote:
As indicated in the quote, in the later D4 equivalent RRS you can adjust for different size tyres by using something like the IID tool etc.
But what about the earlier RRS? Can it be done with it?
Does anyone know?
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #556364 Mon May 14 2018 4:52am
aljo
You could send pat an email @ gap diagnostics đź‘Ť
I’m sure he can help
Post #556366 Mon May 14 2018 6:13am
garrycol
Australia
Thanks - I just thought someone on here would know if it is possible.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #556374 Mon May 14 2018 7:25am
Tim in Scotland
In the UK if you think you have an error in your speedo then you can easily check it using the verge/ hard shoulder markers on any UK motorway and most major A roads in England.
At the side of the hard shoulder on all UK motorways there are small blue and white position posts used by HA to locate you when you have a breakdown or when they are doing maintenance - these are 100m apart and are on both carriways of all UK motorways and many urban dual carriageways. If counting posts every 100m is too taxing then, in England only, there are blue signs with orange or white text on them every 500m that give the motorway number and the distance to the next junction.............. Both can be used to calibrate your speedo along with a good quality timer, and this is actually more accurate than using a GPS.
As an aside, in the last few weeks there has been a big military exercise going on in UK waters and GPS accuracy has been reduced in many areas because of this, and in some sea areas and coastal districts in the North and West of Scotland GPS has been completely switched off......... it is to stop the Navies of the world cheating in the exercise and forces them to resort to old fashioned eyeball navigation, but the rest of us have to suffer getting lost as a consequence !
https://www.thesun.co.uk/news/6155261/roya...-training/ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556382 Mon May 14 2018 8:29am
Bill Portland
that would explain why I ran my kayak aground in the Solent at the weekend (my excuse and I'm sticking to it)! Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #556401 Mon May 14 2018 11:49am
Brit Plumber
They can’t just turn off GPS, it doesn’t work like that. They would more likely retain the relevant crypto key from those they don’t want to cheat. Aircraft such as Typhoon and Tornado need valid Crypto to actually work and if it’s not a valid key, the AC won’t fly. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #556429 Mon May 14 2018 4:56pm
Tim in Scotland
They can and do which is one reason why the EU wants its own system - I’m a day to user commercially and we have received numerous navigation warnings over the last month advising. They only switch it off in set locations, or rather they remove 8 or 12 channels that renders the accuracy so wildly out it is unusable....... USA did the same in the Red Sea a couple of years ago when they were assisting the Saudis with Yemen and further back when they were sending the cruise missiles into Baghdad we had never ending alarms on or ingtegrated bridge systems 24/7 for months when operating in the Middle East. It is one reason why I have GLONASS availability now as well on my ECDIS systems onboard - too many shipboard systems rely on satellite navigation of one nationality or another. China has its own system and India is also developing one for the Indian Coast regions. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556448 Mon May 14 2018 7:33pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
As Tim says, they can - GPS jamming get's advertised when naval exercises are being carried out.
Here is an example - https://www.orcadian.co.uk/orkney-waters-host-military-exercise/ 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #556451 Mon May 14 2018 8:35pm
aljo
Tim in Scotland wrote:
They only switch it off in set locations, or rather they remove 8 or 12 channels that renders the accuracy so wildly out it is unusable....... .
Censored land rover must have bought a huge batch of sat navs with the channel options permanently removed Big Cry
Post #556452 Mon May 14 2018 8:47pm
I compared my speedo to several of the 30mph smiley face speed warning signs that flash the speed up and found at 32mph it never triggered them at 33mph it did. Also compared it to the one's that show your speed when approaching them as well and found it spot on, that was after fitting 275/45 x 21" wheels, so figured the speedo was accurate enough not to get a ticket. If you want a more accurate reading you could always try driving through a few fixed speed cameras at a specific speed then when you get the tickets you will know what speed you were actually doing. Laughing
Post #556459 Mon May 14 2018 9:35pm
Brit Plumber
Jamming is different to switching it off, switching it off is a massive problem and very rarely happens. They can restrict access by changing the crypto for one that has limited issue. military GPS is far more accurate than anything civilian or commercial and by turning it off, it turns off more than just GPS, there is other stuff that runs hand in hand with it. The exercise quoted is one I’ve taken part in a number of times and we always had fully crypto keys, like I say, with out it, the Typhoon won’t work well at all. 2019 5.0 SC SVA (Current)
Post #556461 Mon May 14 2018 9:44pm
Tim in Scotland
Stuff that runs in conjunction with it includes mobile phone networks, street lighting, traffic light system timers and a host of embedded bits in equipment that require super accurate timing, that you never thought needed GPS! I have no objection to loss of accuracy provided we are told about it (which mostly professional user are) - after all I was trained and spent a lot of my profession in the time when we had to use a sextant (or Decca Navigation in coastal waters) to find our position and that didn’t always work out error free and someone often switched off the sun by sending clouds over at the critical moment - loss of GPS signals is nothing new, just that it has an effect on far more people than it used to. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #556475 Tue May 15 2018 8:05am
grey17
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Does anyone know?
Garry
Hi Garry.
Yes, you can adjust the tyre size in the RRS1.
I asked Land Rover and they said no problem, they just
need to plug it in and correct it on the computer.
G
Post #556724 Thu May 17 2018 5:50pm
Eaters
Yes, I have the same. For the car to travel at 70 mph I have to set the cruise at about 77mph. But the speedo appears to be more or less accurate. Weird! Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #556769 Fri May 18 2018 7:22am
Page 2 of 3 <123>
