Home > Technical > steering column
Nige
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
steering column
hi guys just replaced my worn lower steering column ,and come to start it and the HDC special programs fault has occurred ,any ideas ? anyone , i did move the steering wheel when the joint was off,is there a steering sensor? is there a reset procedure BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
two discos v6 off contract (for sale) before they go to scrap
Post #555938 Mon May 07 2018 3:06pm
Nige
ok disconnected the top bolt and reset the wheel position, lights now out, and suspension working again,i think i have snapped the bloody spring thing in the steering wheel ( electronic bit for the horn and control ) BLOODY BANK HOLIDAYS BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #555944 Mon May 07 2018 4:12pm
Nige
sorted ,replacement slip ring , the air bag was a pig to get off though BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #556053 Wed May 09 2018 6:56am
