Home > Maintenance & Modifications > 2012 RRS Autobiography - Rear Video Feed ?
mrluke
Looking to install some rear screens . Is their any harness in place to feed the video ( DVD & free-view) from the front screen to the rear screens ?
The screens are aftermarket , so didn't know if there was a pre wired S video or RCA leads under the center console.
Thanks
Luke
Post #555752 Fri May 04 2018 10:38am
Brit Plumber
I asked the same question last week but know one knew an answer. The only difference I have is that I already have the rear aftermarket screens in the head rests. I've found this which may work
http://www.autotronix.net/nav-tv/rang-rove...sport.html
it claims to repeat what is on the front screen to the rears. Only problem is without VIM, the screens would go blank as soon as you move to drive. Unless this module has something like VIM built in to allow the video to display to the rears only. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #555799 Fri May 04 2018 6:27pm
The RSE module is located under the trim on the O/S off the boot space next to the audio amp, which in turn is linked to the TV unit under the drivers set. Most likely If there is any rear screen wiring already in place I think you will find it in one of these two places, most likely the boot, but as there are so many bits to the RSE system I'm inclined to think it may only be there if RSE was spec'd from new. I have the factory system fitted and wires seem to go everywhere.
Post #555816 Fri May 04 2018 9:50pm
mrluke
Thanks , much apreciated . Will keep the rears seperate .
Post #555958 Mon May 07 2018 6:32pm
mrluke
can you bypass VIM on 2012 sport ? i have dual view screen.
Post #555959 Mon May 07 2018 6:33pm
Brit Plumber
I can’t say for sure but I assume so. It must be a speed signal or a sensor on the gear stick. 2019 5.0 SC SVA (Current)
Post #555993 Tue May 08 2018 10:24am
